Torsion Bar Removal
davidlive
Member
Nov 19, 2011
216
27
18
Simi Valley, California
How are the torsion bars removed ?
Thanks David
78 Royal #749
74 #136
Oversteer is when you hit the wall with the rear of the car, understeer is when you hit the wall with the front of the car. Hp is how fast you hit the
wall, and torque is how far you take the wall with you when you hit it.
Jack up the front of the coach. Place jack stands under the frame where the
front clip bolts in. Remove front wheels and inner fenders. Remove front
shocks. Remove large nuts on axles and remove axles. Remove cotter keys
from lower ball joint and loosen the nut. Install torsion bar tool and
tension it until adjustment bolt and nut are free. Now there is no torsion
on the bar. Separate the lower ball joint from the lower control arm.
Remove bolts and nuts that hold lower control arm. Pry lower control arm
loose from frame tabs and pull control arm and torsion bar forward until
bar separates from pork chop . Install in reverse order.
Salem, Or
78 GMC ROYALE 403
Thanks David
78 Royal #749
74 #136
Thank you James, got them out. i thought they just slipped in, i needed to hit it harder with the rubber mallet :)
78 Royal #749
74 #136
78 Royal #749
74 #136
BFH. Works most of the time.
> 78 Royal #749
> 74 #136
