torsion bar key and unloader tool
skip hartline
Member
Sep 9, 2011
518
5
18
Evening all,
I apologize ahead of time for how long winded this will be but to understand it completely I need to start at the beginning.
I few years ago I Had the socket in the left lower A arm let go and I was able to get the T bar out with a little work and I did the makeshift repair
of putting a spacer in the front of the socket to get the t bar to bite into the reinforced area, I moved the porkchop mount bar back accordingly and
it really gave me no problems. Don't remember the man's name who would get a few people together and order a batch of new T bars, These had the
extended hex area so I could put t bar back in the socket to the original position, thought it was a great ideal so I got a set. When I went to
install them and the bars went down in the sockets where they belong there was so much straight shank that there was no wiggle room to pull the bars
over to the porkchops, could be done with a comealong on each side but there was such a bow put on them I put it back with the spacers and back like I
had it before, but with the new bars. I've always had a problem with my unloader tool wanting to fall over under load and become useless even with the
stock pork chops and even worse with the adjustable ones I use. Tried to use the tool and it is totally useless, it is in the way of the bolt and no
adjustment available short of turning the bolt without the adjuster. My questions are has anyone had the problems I had with the new extended hex T
bars and what tool are others using to unload I currently use the one that looks like a U bolt, I have always kept it lubed up with neverseize. Has
anyone else have experience with the adjustable porkchops by Maxxcam. Also all a arm bushings are in good shape. Just trying to tweek in the front
ride heighth. All comments, ideals, and suggestion welcomed.
Skip Hartline
74 Canyon Lands, FiTech,
3.7 FD, Manny Tranny,
Springfield Distributor,
2001 Chevy Tracker Ragtop Towd
Skip,
We sell few every month, and never receive complaints.
Just need to lay it down and figured out how much or little you need to
adjust.
On Sun, Apr 14, 2019 at 4:24 PM Skip Hartline via Gmclist <
> Evening all,
> and
> like I
> the
> Skip Hartline
http://www.appliedgmc.com
