Check out the breaker on the gen dress thfirst then to the bridge rectifier
then the field mag.
We work on thes about twice a week and seldom address the magn
On Thu, Jul 4, 2019 at 11:40 AM Stu Rasmussen (97381.com) via Gmclist <
> Check that you're not still looking at shore power as your source.
> Some coaches you have to plug the shore power pigtail into the generator
> outlet, some have a two-way lockout switch in the breaker panel to
> change sources.
> If that isn't the problem then start looking at the genny itself.
> Usually loss of residual magnetism is the culprit.
> Stu
> > Well I got the generator started only to find there's no power being
> delivered to the coach. Checked breakers and fuses all seemed good. Now
> what?
> > Happy fourth everyone
http://www.appliedgmc.com
then the field mag.
> change sources.
> Stu
> what?
