To Tank or Not to Tank, That is the question...
> Matt,
> Thank you for a specific suggestion on PL1. I have an October '73 coach and while it drives, rides and camps wonderfully, it has had a slight leak
> for a long time. I now suspect that it is an internal rust problem at the tank and I'll be replacing that and adding a water trap. Years of soapy
> water diagnostics have shown me that my fittings do not leak, even with the complication of the quad bag system. I am also going to rebuild the OEM
> valves with a kit from JimK and your suggestion will be taken. Any further insights?
> Doug
Doug,
Just be real careful, I is easy to mark the O-rings too. Be really ready when you go to buy the Loctite 567, they are really proud of that stuff, but
you will have most of the tiny tube left over when you are done. Carry that in your tool box.
Matt - still on a backup system
