so should we buy real small tires for the front and not change the final
drive ??
gene
>Do you really have the final drive ratio that you think you have?
>Some GMCnetters have reported that they are using wider tires for their
Alcoa
>wheels. The tires may be wider but they are usually also larger in
diameter.
> This has the effect of increasing the gear ratio and can negate some of the
>benefits of going to a lower ratio final drive (higher numerically).
>Goodyear has their specs for the G159LT tires at
>http://www.goodyear.com/us/tires/tirecatalog/G159LTSize.html
>This shows that the 8.75R16.5LT tire has 719 revolutions per mile. The
>LT225/75R16 has 703 rev/mile and the LT235/85R16 has 677 revs/mile.
>The use of the 16 inch tires on Alcoa wheels will give the following effect
>on the final drive ratio:
>3.07 with the 16.5" tires will become 3.00 with the 225 tire and 2.89 with
>the 235 tire.
>3.42 with the 16.5" tires will become 3.34 with the 225 and 3.22 with the
235.
>3.55 with the 16.5" tires will become 3.47 with the 225 and 3.34 with the
235.
>3.7 with the 16.5" tires will become 3.62 with the 225 and 3.48 with the 235.
>The speedometer and odometer can also be affected by a tire change. Going
>from the 16.5 tires to the 225 would make the speedometer/odometer off by
>2.2% and the 235 tire would be off by over 6%. The easiest way to correct
>this is with an accessory gear box attached to the speedometer connection at
>the transmission. There might also be appropriate sized gears that could be
>installed into the transmission.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
drive ??
gene
Alcoa
diameter.
>the 235 tire.
235.
235.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
mr.erf
