Tire monitoring system
Dec 6, 2014
114
I have had a tire monitoring system on since I bought the coach 3 years ago. I lost 3 new tires on my 78 years ago. I found that it was great telling me I had a brake problem, a wheel bearing problem etc. The tire temp reflects how much you are getting on the brakes. Changes in tire pressure when ambient temp changes is very informative and made me pay attention to inflating tires when cold to the proper pressures. My coach weighs 12000# with even distribution on front and back. Those front tires have to hold 3000# each and even load range E are stressed if not inflated properly. I find the monitoring system very assuring as I cruise down the highway at 65 mph.
Jon Darcy ACES
North Jersey 76 stretch, flares, 4 bag, Alcoa's, bunkhouse,MAC Dash,Manny Trans, FiTech FI,Honda 6010
> ...Those front tires have to hold 3000# each and even load range E are stressed if not inflated properly. ...
Two things disturb me here.
First, the max weight on either front axle should NEVER exceed what the Operating Manual says, and 3000# would overload each front axle by at least
625 If you are right about your load distribution, you are asking for trouble. Redistribute the load.
Second, the max weight of a Load Range E tire is 2680 Your tires would be overloaded by 320
I genuinely hope you are wrong about your load distribution.
73 23' Sequoia 4 Sale
Upper Alabama
"Highest price does not guarantee highest quality."
Tire monitors are almost a must if your towing, as it is hard to tell if
the towed is low on air ad going flat.
When you blew the 3 tires, how old were they, and did it just come apart.
On Sun, Jan 22, 2017 at 5:19 PM, Advanced Concept Energy Solutions <
> highway at 65 mph.
> Jon Darcy ACES
Applied/GMC, Fremont,CA
http://www.appliedgmc.com
I hope you are incorrect on your weight distribution. A GMC that weighs 12,000 lbs. normally have 2000 lbs on each tire. That is 4000 on the front axle. I really doubt that yours has 6000 lbs on the front. I don't think the torsion bars and rear suspension could be adjusted to transfer that much weight forward. I suggest that you have it reweighed.
Emery Stora
77 Kingsley
Frederick, CO
>> highway at 65 mph.
>> Jon Darcy ACES
>> GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
After getting new motor at Ken Frey's we went to weigh station down the road from his shop. We weighed each axel and the entire rig. The rig weighed in at 12060# and each end weighed in at about 6000 The front has large steel plates and solid pipes welded to frame. Pictures are on Jim Bounds website somewhere. We think they were installed when it was stretched about 1996. There is no record of front end problems. Since then I installed beefed up stabilizers front and rear and four bag system. Tires are Michelin and I keep them at 80# in front. I have driven the coach about 6000 miles. Former owner used to tow a car trailer to pick up antique cars that he purchased for resale from all over the country. I lightened up just a bit by replacing the Onan with a Honda but nothing else.
Would installing 1 ton mod be advised.
Jon Darcy ACES
We have weighed probably close to 100 coaches at various rallies over the years.
The front wheels usually come in close to 2000 pounds per side. I have seen a couple cone in the 1850 pound range. I have never seen one above 2200
pounds per front wheel.
I suggest that you re-weigh that coach.
Jon,
Who did the stretch originally?
J.R. Wright
GMC GreatLaker
Newsletter Editor/Publisher
Tech Editor
78 Buskirk 30' Stretch
75 Avion Under Reconstruction
Michigan
> Jon Darcy ACES
> Jon Darcy ACES
I am going to say this one more time. And then you can do what you want.
REDUCE THE WEIGHT ON THE FRONT BY 1500 POUNDS IMMEDIATELY.
If you had ever seen pictures of the cracks on the A-arms at the ball joints from overload stress, you would be afraid to drive yours.
Upper Alabama
I would be surprised if the front end actually weighed 6000 lbs, I reckon it
has something to do with the way the coach was weighed. The location of the
front wheels on the scales?
Regards,
Rob M.
The Pedantic Mechanic
USAussie - Downunder
> Regards,
> Rob M.
> ____didn'dt he say it was a "stretch"?___If it was stretched in wheelbase, it would have more weight on he front wheels.
RonC
In the first post he notes there is iron balllast in the front that was likely installed when the stretch was done.. It sounds like the ballast was
an attempt to get weight off the rear. It appears it was overdone.
Steve Southworth
Palmyra WI
What is interesting is he is 2000 pounds heavy on the front and 2000 pounds light on the rear.
I would at least drive over a scale at a highway weigh station. It is free.
When scales are calibrated weights are placed at varying positions as part of the procedure. There is only a small variation allowed.
1977 26 foot 403
