Since I started, I might as well finish the cooling tale: Early on, I
replaced the "horse-collar" with the fiberglass shroud from Frank Jenkins.
That helps the fan to pull cool air through the full radiator. It also
potentially poses a problem (as learned by Detroit's engineers): At road
speeds, the under-hood airflow can be impeded by the spinning fan. So, I
equipped the full shroud with spring-loaded doors which open when there's
pressure in the shroud, but close if the fan's creating suction. I really
didn't see any performance difference after that mod, but they're still
there working, so I only look at them occasionally.
I just realized that I posted photos of that mod 10+ years ago (it makes
most sense viewed last-to-first):
http://www.gmcmhphotos.com/photos/g5567-radiator-shroud-modification.html
I also found photos of the other significant cooling mod I did; addition of
an under-bumper scoop to limit air escaping around the lower portion of the
radiator:
http://www.gmcmhphotos.com/photos/g5632-under-bumper-air-scoop-26amp-3b-rock-guard.html
When I first bought the GMC in '98, Jim Bounds drove it around the block to
check performance before beginning work on it. When we got back, there was
a stream of water squirting from the thrown-rock created hole in that lower
radiator. While a can of Bar's Stop-Leak cured that one permanently, the
grille on the above scoop is intended to minimize the chances of my
aluminum radiator being similarly damaged.
After all this, I should note that the ONLY cooling problem I've ever had
was after installing the Cad500: Climbing the notorious Monteagle mountain
east of Nashville, the temp gauge got up to 237*F. The first person I saw
at the destination GMCMI Convention was Gene Dotson, with one of their new
radiators. My greeting to him was, pointing, "That's MINE.". Never had a
cooling problem since.
On Thu, Jun 17, 2021 at 9:30 AM Ken Henderson
wrote:
> Just a followup on my grille-to-radiator duct: After 9 years in there,
> the truck mudflap material is still standing up well. And the duct really
> does its job: My engine temperature stays within a couple of degrees of
> the thermostat ALL the time. And the duct has, indeed, proven to be a
> handy storage location. There's usually a shallow and a deep cooking pan
> on there filled with odds & ends, like spare brake fluid. It's useful
> space with no other commitment. That duct is one of the most useful of the
> MANY mods I've done to the X-Birchaven.
> Ken H.
>> The front air baffles were on the 77 403 & later coaches. Number of
>> albums on the photo site.
http://www.gmcmhphotos.com/photos/gmc-part-numbers/p63294-air-baffles.html
http://www.gmcmhphotos.com/photos/gmc-part-numbers/p63295-air-baffles.html
>> and Ken H Baffle setup
http://www.gmcmhphotos.com/photos/g6117-grille-to-radiator-duct.html
>> Look at all the pictures in this series and read the captions under the
>> pictures.
>> Do not use plywood in the engine compartment. Use the materials
>> suggested by Ken.
>> J.R. Wright
>> GMC Great Laker MHC
>> GMCGL Tech Editor
>> GMC Eastern States Charter Member
>> GMCMI
>> 78 GMC Buskirk 29.5’ Stretch
>> 75 GMC Avion (Under Reconstruction)
>> Michigan
>> > The radiator baffles were not in all years. They seen to have arrived
>> about the time that the engine mounted "horse collar" for the fan departed,
>> but
>> > that is just my impression and may be inaccurate or completely bull
>> shit.
>> > Matt
>> > Matt & Mary Colie - Chaumière -'73 Glacier 23 - Members GMCMI, GMCGL,
>> GMCES
>> > Electronically Controlled Quiet Engine Cooling Fan with OE Rear Drum
>> Brakes with Applied Control Arms
>> > SE Michigan - Near DTW - Twixt A2 and Detroit
>> > _______________________________________________
>> > GMCnet mailing list
>> > Unsubscribe or Change List Options:
