Hello,
While under the front end today changing out a axel shaft, I noticed a couple drops of anti freeze by the seep hole on the engine water pump. I have
not had any problems with the water pump previously. It has 12,000 miles on it, and no squeaks while running.
Is there anything I should be concerned about? Possible pending bearing failure? Or is this nothing to really worry about since the weep hole is there
for a reason?
I plan on replacing my alternator in the next few days, and that could be the opportune time to replace the water pump if needed.
Thanks,
Scott
Scott Nutter
installed MSD Atomic EFI
Houston, Texas
for a reason?
Thanks,
Scott
Scott Nutter
Houston, Texas
