Timing Mark on Distributor
emerystora
14,608
2
1
Someone recently posted that I had once made a timing pointer for my distributor.
It is shown here:
http://www.gmcmhphotos.com/photos/timing-marks-for-distributor/p1451.html http://www.gmcmhphotos.com/photos/timing-marks-for-distributor/p1451.html
I found that this was very accurate for adjusting my timing.
When I lived at Santa Fe at an altitude of 7200 feet I found that I could advance the distributor anywhere and not get pinging.
At high elevations I found that advancing the distributor gave me much more power.
So I would have it at 25 degrees in the mountains but would have to lower it when traveling.
When I got down to, say 3000 feet, I would drop it to about 15 degrees. When I got to California close to sea level I would put it at 8 or 10 to prevent pinging.
This was all before I had a fuel injection controlled distributor with spark control.
I no longer use the original distributor.
Emery Stora
77 Kingsley
Frederick, CO
> prevent pinging.
I assume that you are speaking of base timing, not including vacuum or centrifugal advance. Not knowing what vacuum or centrifugal advance you had it
is difficult to assess what you had for total timing. I would not recommend total timing beyond about 50 degrees under any condition. Just because
you can run more advance does not mean you should. We don't know what MBT (max best torque) is for the Olds V8, but probably not greater than 50
anywhere. When you run beyond MBT you lose power and economy. At lower speeds and higher loads it is generally safe to assume that you will be knock
limited before MBT. But not necessarily the case at higher speeds and / or with higher octane fuels with these very low compression engines.
Chris Geils - Twin Cities
1978 26' Kingsley w/ very few mods; Headers, Progressive Dynamics 9040, aux trans cooler, one repaint in stock colors, R134a, Al rad, 49k mi
Somewhere around 38° maximum.
Jim Hupy.
> more power.
> > prevent pinging.
> had it
> because
> knock
> It is shown here:
> prevent pinging.
> Emery Stora
> 77 Kingsley
> Frederick, CO
Emery,
Thanks, I knew I had seen it and thought it was a marvelous idea. I do plan to copy that if we are ever over 5KMSL for more than mere moments.
