Jim since you mentioned timing chain I have a question about it. I am going
to change my timing chain and gears in the next month or so to a cloyes set.
Is it possible to do it without removing the transmission and final drive?
>Hey Man,
>I've always been here but I've been so burried with new work and the
>hundreds of direct Emails that I have had a hard time staying awake enough
>to get into any of the net threads. Sorry bout that chief!
>Does the pump fit, does it line up, gasket surfaces mate, offset of the
>shaft measure right and heater hose complement correct? Well the "Bookem
>Danno".
>One bobo I ran into on the last job was the gasket did not follow the mate
>surface at the to and left a gap, yes it did leak and yes we did have to go
>back in and change the gasket, bummer. The time chain set had several
>water pump gaskets to choose from so we had the prob. solved OK, but really
>check that out.
>Hope this helps,
>Jim bounds
>>Jim
>>Nice to see you back. Glad you care about us-----nobody else seems
>>to. The other day I found a water pump in my motorhome. It does not have
>>the right casting #s on the housing but it does have a 4 1/4 inch
>>cast impeller. Do I keep it or throw it away?
>>Take Care
>>Arch
>>> Mark,
>>> I just completed a job which included a new water pump. I ordered a new
>>> one through GM and recieved a steel impeller that was 3 1/2". I then
>>> ordered a rebuild and told my supplier to open the boxes and tell me the
>>> size of the impeller. He came back and said he had ones on the shelf with
>>> the same number with cast & stamped impellers, how about that! The OEM
>>> impeller on the water pump I pulled out was a 4" cast one.
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>Hey Man,
>Danno".
>check that out.
>Hope this helps,
>Jim bounds
>>Jim
>>Take Care
>>Arch
>>> Mark,
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
