I've been going into paralysis by analysis mode looking at the various options for fuel injection plus timing control.
My question - does the automatic timing control on the Howell TBI system know to advance the timing as altitude increases, or is the adjustment based
on operating parameters that are the same at sea level or 10,000 feet - or maybe affected by vacuum (which will drop at altitude)?
Same for the timing control for the FiTech 600hp system. I don't see where there is any knock sensor on the system, so I have my doubts (fears) about
setting it up - at least without a standalone knock sensor.
And the other option is to install a "fuel only" system (Howell or FiTech), and use an adjustable timing control that would work on my existing HEI
distributor (there are a few MSD systems out there that should work, with a 0-15° timing adjustment knob). I'd also want to install a standalone
knock sensor if I went this way, but I like the idea of being able to twiddle my timing depending on load, altitude, and gas quality. Seems like this
might provide the option for a bit better performance in a given situation, unless one or both of the automatic timing control systems are
sophisticated enough to always be looking for the sweet spot in timing advance, while avoiding detonation at all times.
Mark Hickey
Mesa, AZ
1978 Royale Center Kitchen
Mark Hickey
Mesa, AZ
