I am in the process of having my radiator re-cored and after messing with the
fan shroud and radiator bracket,
1) I've decided to cut the bottom off the radiator holder and then re-attach
with my own brackets for easier rad removal
2) Cut the fan shroud in half so the upper part can remain stationary while the
lower half can be easily removed. Question: Somebody had some good directions
on how to do the shroud modification. now I can't find it, anybody know where
it is?
Also, I think I've decided to replace the timing chain. What's so bad about
using OEM type chain and sprockets? Lasted 100,000 so far and since you should
change them every 75,000 or 100,000, the hevay duty ones don't seem to buy you
much except lightening your wallet.
Might as well replace the water pump. It seems Cinnabar's water pump doesn't
have the backing plate (according to recent photos). Aren't they supposed to
OEM?
Thanks.
eric.henning
73 sequoia (97,000 miles)
it is?
OEM?
Thanks.
eric.henning
