Tie Rod Assembly
patrick flowers
1,460
GMCnetters,
Well, the shafts, knuckles and hubs came out from under my GMC today
despite the Georgia heat. I've already spelled out all the scary stuff
I found in another thread. The disassembly process went well. The only
casualty was the right side tie rod end(I tried to use a puller instead
of a pickle fork - dumb!). Looking at these 25 year old parts, I think
I'd be better off buying a tie rod assembly instead of just replacing
the end. Any ideas of a good source for these, or should I just call
Cinnabar?
Gonna' do the ball joints and 80mm caliper upgrade while I'm in there.
Anything else I should be looking for?
Thanks!
Patrick
Patrick Flowers
Mailto:patri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
Can get urethane ones even cheaper from JC whitney.
>In a message dated 98-06-27 17:55:35 EDT, you write:
> Thanks!
> Patrick >>
>Patrick check the entire swaybar bushing set. Gateway has the entire
>set for $35. Only a couple of mine looked bad. Once they were out
>I suprised at how bad they were. I cant speak to how it changed
>handling because I have only driven mine about 50 miles. I can tell
>you it got rid of a couple loud THUMPS I was worried about. BTW
>the Gateway set is urethane in nature. Thats what I did.
>Take Care
>Arch
>> said Arch...
Huh... urethane?
Regards,
John Dolan
jdolan
