Short answer. Miles, and contamination in the oil. There are 3 ways oil get=
s into the combustion chamber. By the piston rings is the major way. Rings=
can last an extremely long time. Their life gets shortened in several ways=
. The choke on the carburetor isn't adjusted correctly. And stays on too lo=
ng. choke pull off not working, carb float too high, enrichment valve open=
too long, metering rods not working correctly. This over rich fuel/oxygen =
fuel charge to the pistons. Gets way over the preferred 14 ppm ox to 1 p=
pm fuel. This slows down the flame front that travels across the combustion=
chamber from the spark plug. ( Indexing the spark plug to the chamber is p=
referred) All this allows some fuel to not get burned. Leaving raw unburned=
fuel to wash sway the tiny amount of oil on the cylinder walls. Plus prod=
ucing excessive amounts of carbon in the chamber. Great if your making sand=
paper. Luging the engine by not shifting down on hills. Puts excessive loa=
ds on rings. Engine overheating can take much of the tension out of the rin=
gs. Ignition timing way off. Valve stems/guide clearance is another expres=
sway for oil to the chamber. Again here. An over rich fuel ratio is very da=
maging. The positive crankcase ventilation system is next. This system gene=
rally has few issue. Replace the PCV valve in the valve cover. And NEVER =
put on ANY pretty valve cover that doesn't have the stock baffle. Not havin=
g that stock type baffle. Makes a very nice express way for oil to the com=
bustion chamber. The Howell EFI with spark control will solve all this exc=
ept the PCV issues. Now to the oil control piston ring. This lower rin=
g on the piston. Is there to make sure that the cylinder walls, and the 2 u=
pper rings get the proper amount of oil. That oil that this ring puts on =
the cylinder wall. Is a mind boggling tiny amount. And more bearing clear=
ance with a HV pump doesn't help. There is absolutely no one on this earth=
that knows more about the 403, and 455. Then the hundreds of engineers at =
GM. And how these engines have held up for going on a half century proves t=
hat. There are 5 changes made on the 455 for the TZE units. 1-Water pump. 2=
- carburetor. 3- lowered intake manifold. 4- Distributor. 5 - higher Nick=
le content in the engine block. The 403 didn't have a lower intake manifol=
d. Just the standard rear wheel drive car intake. A larger bearing clearan=
ce, and a HV oil pump aren't on that GM list. And for good reason. =
So why do some engines fail at 75,000 miles. And some are running well at m=
ore the 200,000 miles. That's in the maintenance. And the carburetor issues=
above. It's the oil dilution by unburned fuel. The main/rod bearings sho=
uld never come in contact with the crankshaft. There should always be an oi=
l film between them. And cleaner oil will not have as much abrasive carbon=
floating in the oil. Frequent oil/filer changes have always been the salv=
ation for you engine. By draining out the diluted oil by fuel, and the cont=
amination contained in that used oil. I've known owners that changed the fi=
lter ever other oil change. That is pure dumb. In the microscopic world out=
there in our engines. Our oil filters. NO MATTER the brand. Are only filte=
ring out the LARGE ROCKS that are traveling around the inside of our engine=
s. And the ONLY way to remove the slightly smaller rocks, then the larger =
ones that got filtered out. Draining the contaminated oil out. The 403 that=
was in our 78 Royale. Had 152,000 miles on it. Was in pure excellent condi=
tion. The log book that came with it. Showed only a hand full of oil/filter=
changes that went over 3,000 miles. Synthetic oils are excellent for the m=
odern clean engines of today. We need to change our oil to soon to take ad=
vantage of their longer mileage cycles. OK. I'll stop babbling, For now. =
GRIN Bob Dunahugh
GRIN Bob Dunahugh
