Changing your power steering fluid needs to be done. To replenish additives=
. There are many additives that are in power steering fluids. Most owners =
never think of changing the PS system. Or even know about the PS filter tha=
t can be cleaned. I know that there's a thought that Automatic trans fluid =
( ATF ) can be used in the PS system. In a pinch. Yes. But will need to =
be changed ASAP. ATF lacks one very important additive. An anti foaming ag=
ent. If you had only ATF in your PS system. You'll get the pretties pink f=
oam come out of the PS pump to clean up. It's not hard to change the PS flu=
id. There's a standard hose clamp on the low pressure hose on the back of t=
he PS pump. Loosen that clamp. then pull the hose off. This will drain the =
PS pump. Then remove the PS filter. This will allow more fluid to drain ou=
t. Then put the low pressure hose back on the PS pump. And secure the hose =
clamp. Refill the pump. And start the engine. Then turn the steering wheel=
full left, then right. Then run your windshield wipers. This process WILL =
NOT change all the PS fluid. I would suggest that after you run the system.=
Change the PS fluid again. Bob Dunahugh
