Excuse my ignorance to this topic but I am green to the GMC motorhome commu=
nity. I=E2=80=99ve learned a few things in the short amount of time we=
=E2=80=99ve owned one but this topic of which front end to run always seems=
to be a hot topic. Again I apologize if these questions sound dumb. But wh=
y is it that there are only 2 options to solve any of the above named probl=
ems with our front ends. With the amount of builders out there and suspensi=
on =E2=80=9Cexperts=E2=80=9D there should be more options. Heavy duty contr=
ol arms are abundant not just relegated to the one ton gm ones that people =
are using. Along with aftermarket suspension components that can accommodat=
e any number of scenarios. Again I=E2=80=99m learning as I go and have had =
the opportunity to build a few suspension systems in custom cars and trucks=
but nothing on the scale of our rigs. Maybe some day when we park ours I=
=E2=80=99ll have a chance to dive in but until then I=E2=80=99ll differ to =
the guys that have tried and experimented with any number of components. =
Sent from my iPhone > On May 15, 2018, at 12:10 PM, Fred > The traction thing is a function of how much weight there is on the d=
rive >> wheels. In a front wheel drive car, the front wheels have more we=
ight than >> the rear unless you have a heavy load. Front wheel drive car=
s have better >> traction characteristics than rear wheel drive. We have=
about 4k of 12k >> lbs on the front axle. If we changed the system to on=
ly drive the center >> wheels like we had a tag axle we would have the sa=
me problem. Tag axle >> systems get away with driving the axle with the m=
ost load and in most cases >> can unload the tag. Have 1/3 of the load on=
the drive wheels puts this MH >> to a disadvantage compared to on with 2=
/3. >> There may be other factors but these are the ones I see. > > =
> many other factors. but the incorrect geometry of the 1-ton would seem=
to make an already traction challenged front drive even worse. > > bu=
t can the 1-ton geometry be corrected with ball joint relocation by modifyi=
ng one or both control arms is my biggest question. if the geometry cant =
> be correct, Im not interested and wont be considering coaches that have t=
he 1-ton front. > > see, when the camber changes, it moves the tire la=
terally and that starts the loss of traction then it gets continued by the =
drive forces. once the > traction is 'broke' its nearly impossible to get=
it back. > > I would really like to have one without the difficult wh=
eel bearings but Id rather have one that can negotiate difficult paved surf=
aces and minor > offroad the best. drive traction is obviously an issue b=
efore any incorrect geometry. > > > _______________________________=
________________ > GMCnet mailing list > Unsubscribe or Change List Opt=
ions: > http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org=
