Tid Bit. Simple way to get park brack cable out of baking plate.
Bob Dunahugh
2,784
4
3
I've heard for decades on how hard it is the get that brake cable out. Here's an extremely simple way to get it out. Get a 3/8" screw hose clamp. Put it around the brake cable housing. About 3/16" from the inside of the backing plate. Over the fingers that hold it in place. Screw the screw type hose down till the fingers are all folded in. Push the cable the 3/16" out the back of the backing plate till the hose clamp comes in contact with the backing plate. While pushing out on the cable. Remove hose clamp. Done with no damage to the cable. DONE. Bob Dunahugh
Dang Bob, You gotta stop giving away our secrets 8)
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
Great trick to do.
Tks, Bob
http://www.appliedgmc.com
I'm too lazy for all of that, I just found the right size (I do not recall) deep wall socket pushed it down the cable and gave it a wrap.
I'll get to do this again real soon as I have a sticking cable that needs attention.
