Many Many years ago. I wanted to know if my radiators cooling capabilities had decreased over time. Because of deposit buildup from leaving anti-freeze in more the 3 years. So, I pulled the thermostat out. Put the coolant that I had drained out, back in. Then went for a drive. If the temps are much lower. Then I knew that the radiator was up to the task.
There are many more areas to cover on this topic of cooling the engine/trans. As to the cooling of our GMCs. And those can be covered if there's interest. In short. Buy the things that you find you need. Not the things that you think you need.
Bob Dunahugh
78 Royale since 2003
4 real COPO Yenkos
Bob Dunahugh
4 real COPO Yenkos
