Tid bit. Caushion on transmission torque converter bolts on rebuilt trannies
Bob Dunahugh
2,784
4
3
If you order a transmission from ANY rebuilders. And I mean any of our vendors. Or local shops. These vendors order torque converters from convertor rebuilders. Our original converters used 3 - 3/8 course SAE bolts. I've seen some of these convertors that have 10MM threads. A 3/8 bolt will screw into the 10MM hole just fine. As the SAE bolt is .019 inch smaller then the 10MM bolt. This 3/8 SAE bolt in that 10MM hole. Can threaten the integrity of the connection years later. I DO NOT care who built the trans, or who is going to install it. Get a 10MM coures bolt. And test the size for yourself. If the bolt goes in fine. It's 10MM for sure. If that 10MM will not screw in. It's 3/8 SAE course hole. Seen this get by some of the best. DO NOT let anyone stop you from this test. Could cost YOU a lot later. Not them. Bob Dunahugh
SO TRUE! We even found metric threads in some of the torque converters
Manny had shipped to my place for his rebuilds.
BE CAREFUL!
On Sun, May 12, 2019 at 2:33 AM Bob Dunahugh via Gmclist <
So if you do end up with one tapped for metric... should you just use the appropriate metric bolt, or would it be better to tap and helicoil it to the correct standard thread size?
> BE CAREFUL!
> Ken H.
The appropriate metric high-grade (9) torque converter bolt should be
readily available from any parts store; certainly any transmission shop.
DON'T just install whatever 3-5 grade bolt you can find! Else you'll be
justified in losing sleep worrying about having only 3 bolts restraining
all those Olds HP.
On Sun, May 12, 2019 at 8:29 AM Dave Stragand via Gmclist <
> > On May 12, 2019, at 8:26 AM, Ken Henderson via Gmclist <
> > BE CAREFUL!
> > Ken H.
> inch
> And
> sure.
> by
> YOU
> >> GMCnet mailing list
Just ran into this problem with a trans that Manny built. Someone here called me to say that the last bolt that he torqued striped out. I went to looked at the problem. We put a 10MM bolt in. And torqued to the proper FT LBS.
Next you need to find out if a torque listing for a specific bolt. Is given for a lubed bolt, or dry. If that bolt called for a dry torque. And you lube it. Or put Lock Tight on it. You WILL over torque that bolt. There are charts out there that cover this. I pay close attention to this in the race engines, or GMC engines I've built. Many builders don't pay attention to this. Devils in the details. Yes. I get anal over this stuff. Bob Dunahugh
Sent: Sunday, May 12, 2019 7:25 AM
To: GMC Mail List
Cc: Bob Dunahugh
Subject: Re: [GMCnet] Tid bit. Caushion on transmission torque converter bolts on rebuilt trannies
SO TRUE! We even found metric threads in some of the torque converters Manny had shipped to my place for his rebuilds.
BE CAREFUL!
Our shop we try not to stock metric fastner , but we stock converter bolts
as we run into them frequently.
On Sun, May 12, 2019 at 7:19 AM Bob Dunahugh via Gmclist <
> LBS.
> Bob Dunahugh
> From: Ken Henderson
> To: GMC Mail List
> Cc: Bob Dunahugh
> BE CAREFUL!
> Ken H.
I've checked 3 transmissions that Manny did. 2 need metric torque converter bolts. One needs SAE bolts. These are what Manny ended up having been delivered to him. Manny did nothing wrong here at all. This is happening to all trans rebuilders. This is an error that can happen to any trans installer. You need to check these for yourself. Or bring this to the attention of your installer. As most don't deal with these older vehicles. Bob Dunahugh
Sent: Sunday, May 12, 2019 1:33 AM
Subject: Tid bit. Caushion on transmission torque converter bolts on rebuilt trannies
It is not an error. GM switched to metric threads in their transmissions
about 1975. But, not in all plants at the same time. When they were
switching from Dyna-flow and the iron case 4 speed Hydramatic and 2 speed
Powerglide to more modern designs like the 350 and 400 series, some plants
tooled up with metric specs. Just what they did.
On Tue, May 14, 2019, 7:23 AM Bob Dunahugh via Gmclist <
> Bob Dunahugh
> From: Bob Dunahugh
> To: gmclist
> rebuilt trannies
