Hi all - I'm a newbie, just bought a 76 Birchaven (Coachmen, side bath) a
few weeks ago and am in still in the process of replacing dubious parts
that are readily apparent. "Twitchy" handling in driving it home, will
look into that later, got a pair of KYB front shocks on order thanks to
this list.
Trying to get the unit trustworthy in time to register for the 25th GMC
anniversary rally in NC. While there *are* more newbie questions, this
one's got me stumped.
There is about an inch of slack in the throttle cable, preventing the
secondaries on the carb from ever opening. Ordered a new cable from
Gateway (which won't work without modification BTW, going to return it
hopefully), and lo and behold it was the same length as the old one!
I also need the 1/4 inch ID to 7/16 OD bushing at the carb for the throttle
cable.
Can't get the trans to kick down even with cable jury-rigged tight at
accelerator pedal, but secondaries *does* open now.
Bought a 455 oil cooler tube/line kit from JR Slaten and couldn't get the
tubes to fit due to interference with the exhaust manifod, so am trading it
for a 403 kit. (?)
Wipers come on unexpectedly. Yes I know they are hydraulic. Could this be
an over-pressure problem at the pump or just a worn valve?
Gads, who knows what other horrors await??
Any feedback most welcome!!
As always, best regards.
~ Ritch & Betty Hwang ~ mailto:rhwang
~ =^..^= Trinket ~ the shy Persian kitty
~ 76 GMC Birchaven ~ RVClub 00930 ICQ# 6408591
(B}>
this list.
cable.
for a 403 kit. (?)
(B}>
