Are you guys talking about the power level or electro level systems? Big
difference in pump up times. won't the initial pump up time for the power
level system exceed the duty cycle of the Thomas Compressor? The Dana can
be run continuously for long periods of time if necessary with no damage,
for instance if you are on the road and have an unexpected air leak. Can the
thomas do that?
> This pump is not a continuous duty
>> pump but a intermittent pump.
>> It is designed to run for a 15% cycle. 4 minutes on and 20 minutes
>> off. So seconds on and minutes off is perfect for us.
>OK,this is some good data from Darren. Now, anyone who has the Thomas
>315 supplying the OEM 2 bag suspension with no air leaks, can you report
>that the from a fully delfated start, your Thomas 315 will pump up to
>the 110 psi in less than 4 minutes?
>Phil Stewart
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
thomas do that?
>Phil Stewart
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
