Scott,
Which configuration of the Thomas 315 are you considering?
I'm the one who started this discussion when I installed the Thomas 317CDC56/12
last January. The 315CDC56/12 has the same stroke (0.56") and max. pressure
rating (150psi) as the model that I installed. It's flow rate is slightly lower
than the 317 (about 7%) but after living with the 317 for 9 months I can say
that I would have no reservations whatsoever about using the 315CDC56/12
instead, and given the price difference I would go with it if I had it to do
over again.
The 315CDC45/12, however, has a shorter stroke (0.45") and max. pressure rating
of 130 psi. Its flow rate, however, is close to the model 317 that I installed.
Does your Thomas rep think the 130 psi version is suited for our application?
Just curious. I was told that compressors are happier when operating comfortably
below their max. pressure rating; that's why I went with the one rated at 150.
Richard
> Today I got a call from the Thomas Compressor Rep. About 2 months ago there
> was quite a bit of discussion. I guess I made an inquiry to Thomas about
> purchasing a quantity of them. (30) IIRC we were discussing using the 315
> for the air bags and thinking about also using its vacuum capability for
> back-up to brake vacuum booster. Has anyone installed the Thomas 315?
> I had him give me a price if I bought them through Adohen Supply Co..
> Quantities were 10-29 $114.14 and for 30-59 $103.00. plus shipping costs
> which would be drop shipped from Wisconsin. Shipping wt was around 4.5lbs.
> Any thoughts?--
> Further discussion revealed Thomas will ship one compressor for experimental
> purposes at no cost for 30 days. If it works you pay, if it doesn't you ship
> it back, no questions asked. I am not even close to being able to do
> retrofitting with that system however if there is someone who would like to
> tinker speak-up and I will give you the Reps phone number and you can pursue.
> Scott NEHODA'S
> BACK YARD
over again.
Richard
> Any thoughts?--
> Scott NEHODA'S
> BACK YARD
