Now this is EXCITING!
I'm still using the original Dana which is under the streetside bed in my
'76 rear bath Royale. Either it's no good or the check valve is leaking, or
both, so that the compressor cycles for 30 to 45 seconds every couple of
minutes (even on "hold"), and it takes forever to raise the coach. Also, I
want to add an auxilliary vacuum pump for the brakes.
If I'm correctly understanding the recent thread, there's a good
possibility I can replace the old Dana with a Thomas 315 or 317 to fix both
problems. Here's what I envision:
1) Mount the new compressor in the engine compartment (where it wouldn't
need a long power lead), together with the solenid valves & etc. (See note
below) including a quick-connect fitting to inflate anything else that
needs it.
2) Run a 1/4" copper pressure line back to where the Dana used to be, tying
it to the check valve (I'll replace that too).
3) Run a 1/4" copper vacuum line to the brake booster, with the appropriate
vacuum switch
to turn on the pump when vacuum is needed.
An added benefit for me would be that I could easily direct my mechanic to
do the work.
Note: If someone could PLEASE make the diagram and part numbers available
for a pressure / vacuum system, I believe many could benefit by this
moderately priced upgrade.
Watching.
Dave (& Dege), Santa Barbara, '76 Royale 26'
needs it.
vacuum switch
do the work.
Watching.
