Thinking of putting my extra 78 rear suspension under my 73. Should work. RIGHT.
Bob Dunahugh
2,784
4
3
I'm getting a crash course on 73 GMC's. Just not up to the details on them. I have two choices for this 73. One. Service the wheel bearings brakes and the suspension components that are on the 73 now. Two. Put the 78 rear suspension under the 73. Then all that work that had been done by me a few years ago when it was under the soon to burn 78. Then this could be a good upgrade for the 73 when I sell it. Plus in reality. It's just simpler to switch the 78 to the 73. And avoid the rebuilding the 73. Installing 77 gas tanks that have the larger gas fill pipe. And since the fill pipe is out. I can install a fuel return gas line fitting for the Howell EFI. This 73 is going to be a nice GMC. Bob Dunahugh
What a glutton for punishment!
ken, are you saying there is a lot of difference between the 2 years?
I know the rear GVW increased between the years but did the parts really
change?
On Sat, May 19, 2018 at 4:17 AM, Ken Henderson
> Ken H.
> the
> by
> could
*John Phillips*
John,
I was just ribbing Bob about the amount of work he's putting into that '73
-- someone's going to get a jewel!
As for the bogies, I suspect they're directly interchangeable. As far as I
know, the spindles and the swing arm pins (and related parts) are the only
differences. Even the spindles should be the same if the '73 had the
recall performed which replaced them. Even if there are other differences,
I doubt they'd be as difficult to correct as it would be to rebuild the '73
bogie. I strongly suspect that not only the pin bushings, but the bogie
housings around those bushings, are badly worn, requiring difficult (and
expensive) machine work to restore the housing.
On Mon, May 21, 2018 at 5:12 PM John Phillips
> change?
> > Ken H.
I just did a early to late conversion this winter. The bogie boxes are
different, as well as the bogie arms. The spindles, after the recall, are
the same. Better to find a late coach and swap the assemblies. If you do a
total rebuild, it is a whole bunch of work. Pressing out the top hat thrust
bushings will improve your vocabulary skills, as will removing the bogie
arm bushings, as the arms are step bored, and cannot be pressed through the
assembly. I used a die grinder, ground the bushings paper thin, and an
expanding collet slide hammer to remove them. Oh, yeah, I learned some new
vocabulary along the way. Reaming the semifinished pin bushings is a lot of
work if you don't have a mill. I do them by hand with a critchley expansion
reamer. A good winter shop project.
John,
> change?
> > Ken H.
Thank you Ken and James,
I thought there was a possibility that my 74 vintage bogies could be safe
at the GVW of the newer coaches.
> John,
> Ken H.
> > change?
> > > Ken H.
*John Phillips*
Is there a way to tell if the bogie recall was performed?
On Mon, May 21, 2018 at 2:45 PM, Ken Henderson
wrote:
> John,
> Ken H.
> > change?
> > > Ken H.
Hey, Jim,
I just discovered the easy way to remove the suspension arm bushings from
those stepped bores: Just go to your tool cabinet and get out a 1-1/4" or
1-1/2" tap and screw it into the bushing a few turns, then drive the
combination out with a brass drift (with gentle taps)! 'Least that's how
Service Bulletin 75-TM-4 says to do it! :-)
Yeah, me too -- don't have taps anywhere near that big! I used a tail pipe
cutter chisel to remove them when I did mine in '98.
Many different minds attacking the same problem make easy work of any
problem. I will try your method if there is a "next time " for those
bushings. Thanks.
> Hey, Jim,
> Ken H.
> the
Cesar,
I just read the Service Bulletin under which the spindles were replaced.
The only marking mentioned was a sticker which should have been applied
beside the Vehicle Identification Label (VIN plate under the right hood).
I wouldn't depend on it still being there. Unless someone knows of another
way, I guess pulling a wheel to check the spindle size is required.
​Ken "Glad mine's a '76" H.
On Tue, May 22, 2018 at 12:13 PM Cesar Carrasco
Just a WAG (Wild Arse Guess) here, but wouldn't the cost of one of those big taps from horror fright be worth it to do the job so easily????
AND, you could loan it out to other GMCers who needed to do the same job!
D C "Mac" Macdonald​
Amateur Radio K2GKK​
Since 30 November '53​
USAF and FAA, Retired​
Member GMCMI & Classics​
Oklahoma City, OK​
"The Money Pit"​
TZE166V101966​
'76 ex-Palm Beach​
k2gkk + hotmail dot com​
Sent: Tuesday, May 22, 2018 11:52
To: GMC Mail List
Subject: Re: [GMCnet] Thinking of putting my extra 78 rear suspension under my 73. Should work. RIGHT.
Hey, Jim,
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Flist.gmcnet.org%2Fmailman%2Flistinfo%2Fgmclist_list.gmcnet.org&data=02%7C01%7C%7C30436169fdd14813198008d5c00544d1%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636626051211393105&sdata=q8iZVPE0v7ZuEGortycOKuuJiZ0Lo0VFb%2BCNigX2jtc%3D&reserved=0
Cesar & Ken
Read here about how to determine if the spindle recall has been completed.
I won't summarize as it may lose correctness.
http://www.gmcmotorhome.info/rear.html
Dennis
> Cesar,
Dennis S
73 Painted Desert 230
Memphis TN Metro
Pipe taps should work just as well. Some of us have pipe threading tools that are larger.
Frederick, CO
> Hey, Jim,
> Ken H.
Thanks, Dennis,
I've got a spare hub, which should be for a 1-1/2" spindle; I'll check it
for 8 notches later today.
> Cesar & Ken
> Dennis
> > Cesar,
> another
> Dennis S
> Memphis TN Metro
Mac,
I couldn't find a tap that large on HF, but Amazon lists some for about
$35. If I ever do that job again (unlikely), I'll ping my plumber buddy
for one of his. (Or Emery.) :-)
On Tue, May 22, 2018 at 1:40 PM D C _Mac_ Macdonald
Local pawn shop should be a good source for a cheap 1-1/4" pipe tap.
On Tue, May 22, 2018 at 1:36 PM, Ken Henderson
wrote:
> Mac,
> Ken H.
I checked both my 73 and 74 and both have the 8 notches on the hub centering shoulder. When I have more time I'll check the spindle size. I did not
see a sticker next to VIN plates.
Thanks again for the info!
1973 Sequoia 23’
1974 Glacier 26’
> not see a sticker next to VIN plates.
Cesar,
It sounds like you lucked out on that one.
Mine has the update and no sticker.
CAUTION: If you go to buy rear brake shoes, the listings are often wrong for the updated brakes.
You want the later version shoes.
Again a small caution about the 73-23.
Don't count on good information from the X7525 book or set.
You have to collect the X7425 manuals from Bdub's link site.
