thermostats
richard waters
1,236
> The Robertshaw 330-180 is the one you really want to use. It is a High flow low restrictive type. As far as I am aware there are no other that can match it for service. AutoZone carrys it for under $5.
> J.R. Wright
John,
Now you have me confused. My coach is now running just fine at 190 degrees. A while ago Emery Stora recommended a thermostat that I believe is the 190 degree guy. Now you recommend a 180 degree model.
Which way do we go here?
Richard Waters
'76 PB, Troy, MI
PS Keep up the good work on the Great Laker newsletter!
Subject: Re: GMC: Operating Temperatures
Date: Fri, 31 Mar 2000 10:12:59 EST
"The recommended thermostat is a Robert Shaw 330-195. I don't know that NAPA sells this one. If you have an AutoZone in your area they sell it. I would try this thermostat before you do anything else."
My motor from mondello has no thermostat, just a restrictor....... so make
you own choice.
gene
>Richard,
>Your showing no mercy here! The manual says the the correct range is
190Deg F thermostate and the number for that one would be 330-190. I too
have chosen to go with the 180 degree for the same reason as Tom has.
Either one will work and I have heard of other GMCers have gone as low as
160 units. The choice is really yours and if your happy with the 190 then
don't change it.
>John
>> match it for service. AutoZone carrys it for under $5. > > J.R. Wright
>> John,
>> degree guy. Now you recommend a 180 degree model. Which way do we go here?
>> Richard Waters '76 PB, Troy, MI
>> From: EMERYSTORA
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
>Thanks everyone for the help. However, after spending all afternoon calling
>Parts suppliers in a 150 mile radius, we still have not been able to find a
>Robert Shaw thermostat. Jegs and Summit no longer Carry them and carry the
>Mr. Gasket one as there top line one now. It is brass/copper construction,
>high flow, not rpm sensitive and opens at the designated temp (within 2
>degrees). Does this one seem to be comparable to the RS one? If not, can
>someone buy one to sell to us? Any help would be appreciated. We said we were
>behind the Redwood curtain - we didn't mention that you could see the end of
>the earth from here too. No AutoZones, no Pep Boys, no Grand Autos, etc., in
>this armpit of the world. We do have a NAPA and a Kragen, but they could not
>help.
>Thanks again in advance.
>Bert and Fay
>76 Glenbrook
I can mail one out to you today. Do you want the 195 degree or the
180 degree one? Dow you want it to go Priority Mail at $3.20 or
regular mail? Send me your name and address and I'll get it out
within an hour after getting your reply. Maybe you'd like two?
Santa Fe, NM
