John,
I didn't mean to put you on the spot!
It's interesting that your response to my post just appeared in my mailbox at 3:50PM. You wrote it this morning sometime. Between my earlier post and this one, a small discussion started on thermostats. Wonder why it took so long for this to hit my mailbox when I received all the answers to this one before I got it. Must be a time warp in the GMC net. Or was I (my computer)
abducted briefly by aliens interested in the advance technology of the GMC Motorhome?
Richard
> Richard,
> Your showing no mercy here! The manual says the the correct range is 190Deg F thermostate and the number for that one would be 330-190. I too have chosen to go with the 180 degree for the same reason as Tom has. Either one will work and I have heard of other GMCers have gone as low as 160 units. The choice is really yours and if your happy with the 190 then don't change it.
> John
> > > The Robertshaw 330-180 is the one you really want to use. It is a High
> > flow low restrictive type. As far as I am aware there are no other that can
> > match it for service. AutoZone carrys it for under $5. > > J.R. Wright
> > John,
> > Now you have me confused. My coach is now running just fine at 190 degrees.
> > A while ago Emery Stora recommended a thermostat that I believe is the 190
> > degree guy. Now you recommend a 180 degree model. Which way do we go here?
> > Richard Waters '76 PB, Troy, MI
> > PS Keep up the good work on the Great Laker newsletter!
> > Subject: Re: GMC: Operating Temperatures
> > Date: Fri, 31 Mar 2000 10:12:59 EST
> > From: EMERYSTORA
> > "The recommended thermostat is a Robert Shaw 330-195. I don't know that
> > NAPA sells this one. If you have an AutoZone in your area they sell it. I
> > would try this thermostat before you do anything else."
Richard
> Richard,
> John
> > John,
> > From: EMERYSTORA
