> My temperature gauge is fluctuating from well over 200 down to 165 so I'm pretty sure the thermostat is bad should I put in a 180 or 195
Allan,
With no clue what the coach is or where you are, this is really tough to answer.
But,
What you are seeing could be an artifact of low coolant or a sticking thermostat.
As this is not good for the engine, I suggest that you pull that existing thermostat and do a "Pot on the Stove" test. If any doubt remains, replace
it. Either 180° or 195° will do, it mostly depends are where you will be driving.
