Run the factory thermostat temperature. Your thermostat was designed by GM
engineers to maintain a minimum running temperature. They calculated the
total expansion of the pistons, rings, rods, bearings and like that. Most
notable is that before you have reached running temp, your pistons have a
tendancy to rock in the bore, since they haven't expanded completely to
their designed size. As they rock, they wear heavily on the lower portion of
the skirt and wear the cylinder bore to a taper (this is bad). Additionally
the rings break away from their sealing edge allowing blow-by gasses to
contaminate your oil. As the rings move inward and outward due to this
rocking they wear the ring lands wider and eventually a step is formed. This
reduces the gas loading of the rings which again contaminates your oil, and
as you mentioned reduces fuel economy and power. The oil temp was also
calculated, which must reach a temp high enough to boil off the moisture
(condensate) to reduce sludging. Additives help but here temp is a major
factor....I could go on but you get my point. Make it run cooler yes but,
don't drop T-stat temp to do it.
JGreen - a Ford guy w/ '73 Desert
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of David L.
> Greenberg
> Sent: Friday, July 31, 1998 6:21 PM
> To: gmcmotorhome
> Subject: GMC: Thermostat temps
> At the risk of inciting mayhem I gotta tell ya, I switched to a 165f
> thermostat and my analog water temp gage runs a lower temp than when I
> had a 195f thermostat. Am I trading off something I don't yet know about?
> I have noticed my annual economy dropped off last year by about 15% but I
> attributed that to my engine getting tired (at 286k miles)!
> What else is the lower thermo costing me?
> Jump in!
> Dave Greenberg
> GMC Motorhome Registry
> 200 MacFarlane Dr
> Delray Beach, FL 33483-6829
> 1977 Eleganza II
> _____________________________________________________________________
> You don't need to buy Internet access to use free Internet e-mail.
> Get completely free e-mail from Juno at http://www.juno.com
> Or call Juno at (800) 654-JUNO [654-5866]
> [mailto
> Greenberg
> To: gmcmotorhome
> Jump in!
> Dave Greenberg
> 200 MacFarlane Dr
> 1977 Eleganza II
