When my GMC is cruising/loafing the temperature is approx 208 degrees. =
It'll
go up with terrain as well as with traffic jams. In stop'n go traffic of =
a
few hours it is not uncommon to see 225-230 and then the fan clutch =
kicks in
to bring it back down. Same for going up long hills, i.e. the Grapevine =
into
LA or I10 out of LA, etc.
I just returned from my maiden voyage (from hell) of my 76 Palm Beach. =
I put on 2,700 miles from Denver thru Las Vegas, to Yosemite, Monterey =
and back home via Las Vegas. With a new analog water temp gauge, I ran =
mostly between 190 and 200 degrees except when climbing long hills such =
as up to Eisenhower tunnel and Vail Pass on I-70 where I ran 220. On a =
steep grade on I-70 in Utah in the hot sun I ran the hottest: 230. =20
My transmission failed in Yosemite and I had to be towed from the park =
and delayed for 3 days. I had to return to the transmission shop to =
have the transmission chain replaced and lost another day and was $1600 =
lighter in the wallet. My Wife wasn't crazy about the coach to begin =
with and she says sell the coach. We'll see. (Also, like mentioned by =
someone else before, my Wife does not like sitting in the co-pilot's =
seat and I can understand why. Anyone figure out how to block some of =
the view out of the front windows?)
FWIW going westbound thru the mountains, I was able to go 35-40mph up to =
Eisenhower Tunnel and Vail Pass. The grades are steeper coming =
eastbound where I was only able to go 25-30 mph. Is this consistent =
with others experiences? Going eastbound on I-15 from Barstow to Baker, =
this is the longest grade that I have ever seen. But, it wasn't as =
steep as the mountains and I was able to do 40-45mph. I have the =
original final drive - has anyone traveled these grades with some of =
the aftermarket units? What speeds were you able to maintain and how =
much did it cost to upgrade? I surely can see that pulling any toad =
with my present configuration is out of the question.
I had put Syntec synthetic oil plus Prolong oil additive in the engine =
prior to the trip. The best news of this trip was that I used no oil =
during the whole 2,700 miles. =20
I ran the generator and the roof air conditioner the whole trip. Going =
thru the desert (it was 98 degrees at midnight in Baker CA) the a/c was =
bearly adequate. During the day in the hot sun, the roof a/c couldn't =
keep up with the heat. Fresno, Las Vegas, Oakhurst CA were all over 100 =
degrees. What are other's experiences? Are the new roof units much =
more effective than my 22 year old unit? My unit seems to throw out =
adequate could air in 85 - 90 heat but just can't handle the higher =
temps. My dash a/c unit is next to useless in this kind of heat.=20
I haven't calculated my mileage yet but it seemed to vary between 4.5 =
mpg and 6.5 mpg, depending on the grades I was climbing. This is with =
the generator running full time and driving 70 - 75mph whenever the =
terrain would allow.. =20
I have a vibration in the coach that I will need to address if I am =
allowed to keep it (I do have a for sale ad in the local paper). From =
the wear on the passenger side bogie tire, I need to have a six wheel =
alignment done. What do I need to look for in an alignment shop to be =
sure they can handle this? How much should this cost?=20
Any other ideas on how to quiet down the noise in the coach (other than =
slowing down). At 55mph the coach is fine; at 70 mph it's pretty noisy =
and vibrates a lot.
Thanks
Bob Fukumoto
(If I get to keep it)
It'll
a
kicks in
into
and vibrates a lot.
Thanks
Bob Fukumoto
