Resurrecting this thread if ya'll don't mind. I am determined to create a ThermaSan system from scratch, meaning I am starting with no parts but find
the benefit of such a unit so appealing that I cannot shake the idea from my head. Anyway I have purchased a pump and motor from your favorite auction
site. Next is to create the two brackets' the motor bracket and the pump bracket. I noticed that the original system had the pump with the side with
the protrusion on the shaft pointing away from the motor, however I am probably going to make the motor to pump connector with my 3D printer, so to
make it thicker and stronger I would like to use of the other end of the shaft (i.e. Turn the pump around). I don't have the pump in front of me but I
believe it is non-directional hence this should work with no problems? Anyway Matt has some great pictures of his system online (Thank you, these are
a big help) but some dimensions would be very beneficial if anyone could provide these. Or I don't suppose anyone has any extra parts lying around
they want to part with? Wishful thinking. Also I need to know which terminals are connected to +12 and which to ground, or cross-connected to each
other. I am trying not to pester Matt to death with questions even though he has graciously offered his expertise.
Thanks as always everyone.
Rich Kinas
1976 Eleganza II
Orlando FL
Rich Kinas
1976 Eleganza II
Orlando FL
