Thermal barriers
steven d. ferguson
874
deals with Thermodynamics plus' and where and what to Ceramic Coat,
not just Headers ,but intakes ,Piston's ,Piston Skirts,Combustion
Chambers,
Exhaust Ports
Not to cast doubt on what I believe is advanced technology but there are
some caveats to thermal coatings.
A well respected engine builder here recently went through a new 502
crate motor for a customer. At the customer's request the builder added
some upgrades to the engine, including thermal coatings on the pistons
as well as other internal surfaces. About 1,000 miles later, after
break-in, the customer was experiencing fairly high oil consumption as
well as increased levels of noise from the engine. I got so bad that
finally he (within 2,000 miles) returned the engine to the builder for a
look-see. That motor was literally worn out. It was as if someone had
put a fine silica sand in the oil. The only items that could be
salvaged were the block, (needed a .030 overbore) the crank, (had to go
to .020 under) and the rods, (which needed to be resized). Everything
else was junk including the rockers & guides. All of the parts were
sent back to the coater (well known and also advertises in several
enthusiast publications) & they went .....goodness! And that's all they
did. Absolutely no follow up and no response or effort for any relief
no matter how well the blame pointed in their direction.
I know and lots of others know that thermal coatings are the way of
the future but there are burns out there so choose wisely.
Steve Ferguson
