I don't think I would spray anything flammable around with the engine
running. Any errant spark could start a fire. May I suggest contact cleaner.
It is inert and if a vacuum leak is present the engine will stumble. To test
the brand you use, a quick squirt down the throat of the carb will tell if
it works. I have in the past used WD-40 as a starting fluid on diesels.
Didn't know they had taken the propane out. Thanks for the info.
Terry Skinner
Webfooted in Washington
Terry Skinner
