One big advantage. Is that these Benz units are PROACTIVE as far as when to=
engage. As they react to your engine block temps as the water comes out =
of the cylinder heads. And is heading TO the radiator. With the REACTIVE =
OEM unit. (1) First you have to get the engine block hotter then normal. (=
2) Then this hotter then normal water needs to get the radiator. (3) Next =
this hotter then normal water needs to heat up our very large radiator. (4=
) Then the hotter then normal radiator needs to heat up all the air going t=
rue it to hotter then normal temps. (5) Next all this hotter then normal a=
ir needs to heat up the fan clutch. So that the fan clutch finally finds o=
ut that there's an over heating problem that started sometime ago. That's h=
ow our antiquated OEM fan clutch works. So is the Benz unit a good idea.=
And not just another gig it? YOU BET. Then on top of that. You can turn i=
t on as YOU want. Then there's a light to tell you when it's on. I love my =
403. And want to keep it as healthy as possible. Thus helping to keep us f=
rom ending up at the side of the road. Bob Dunahugh 78 Royale __=
______________________________ From: Bob Dunahugh =
Sent: Saturday, February 24, 2018 4:27 PM To: gmclist=
Subject: Anyone install the Mercedes Benz electrically controlled fan cl=
utch on a 403 yet? I know Matt Collie has. And he has this answer.=
The Benz unit locates the back of it's fan at the front of were the stock=
fan is located. It's looking to me that this puts the Benz fan well into t=
he stock fan shroud's cone area. Thus I'm thinking that I don't have to cu=
t my now two piece plastic fan shroud. The Benz fan has about a 1" large=
r dia. Bob Dunahugh 78 Royale
