Good Day,
I have removed the failing muffler from the 6000K Onan as its done and am wondering if there might be a known supplier or part# that is helpful sourcing something usable?
I found it easy to source a muffler with the same dimension of mine (13" length 4" diameter side inlet end outlet) however it is a tractor muffler, and I do not consider it quiet enough for our needs. Noticed Onan has a 22" length with a 19" body # 155‑1258.
Might there be a known workaround for this muffler issue??
Thanx
Thanx
