The old gas gauge again
scott shean
108
>Where does the low-fuel light get its signal
>from (the sending units)?
>GaryB
>76 PB in Ca
Gary, the low fuel light is activated by a low fuel switch that
reads the voltage from the fuel level senders. It is not a
separate signal. If your fuel gauges work, then the problem is
behind your dash board. The first thing I would check is the
light, the socket, and the printed circuit in the "Tell-Tale"
light panel.
I hope this helps. Its no fun to run out of gas in one of these
things.
Scott Shean
Baton Rouge, LA
78 Royale
Gary, most responses to your question will be, yes, the tanks are plumbed
together and a you drive the fuel sloshes back and forth bwteen tanks.
As I read your close call (running out of fuel) I kept waiting to read
how much gas did your tanks take from empty plus the gallon or so you
didn't use (of the 5 extra) getting to the pumps!
I once put 50 gallons in mine but the light had been on for miles. This
is a stress builder, especially if you are in some remote area (like I-10
in West Texas!
Dave Greenberg
GMC MOTORHOME REGISTRY
Seagate Towers 200 MacFarlane Dr PH4
Delray Beach, FL 33483-6829
Say Hea Bud
running on the top of the tank is better.
gene
( I am home finally)
>>GaryB
>>76 PB in Ca
>light panel.
>things.
>Scott Shean
>Baton Rouge, LA
>78 Royale
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
