Thanks
brewer bob
31
Hi all,
Thanks for the advise recently.
In all my nosing around the web, I'm still unable to find a good
resource that differentiates between different models: Royale, Eleganza,
Eleganza II, Palm Beach, etc.
The fellow with the Royale seemed to think it was a step up from the
Eleganza, but that's difficult to verify. Does anyone have any old GMC
literature they'd be willing to part with?
Thanks for any info.
Regards,
Bob
Arch the original GMC part # for the brake hose (original equipment) is
GM9758214 and that crosses to a Wagner F86578 #$36.31, or NAPA 36675. Hope
this helps.
>Hey Folks!
>I am in trouble. Today I have been replacing ball joints front shocks
>and converted over to the larger brake calipers. Yes patrick will have
>all the pics. Heres my problem---------I used a NAPA part # posted
>here some time ago. I also checked other sources. I can not find
>front brake hoses that will work. Can I bend the steel line that comes
>off the banjo fitting????? Never bent that kind of steel line before.
>If any body has a good part # for front brake hoses using the 80MM
>caliper I sure would like to hear it. I am closing in on the mechanical
>part of this rehab and now I up against the wall. I was planning to roll
>this weekend-------?????????
>Any help you all could give would sure be very welcome.
>Thanks in advance.
>Take Care
>Arch
What larger caliper?
>In a message dated 98-05-12 23:44:52 EDT, you write:
> this helps. >>
>Tom
>Thanks but it wont help. I went with the larger caliper now I must find a hose
>to work with it. Tkanks for your help though.
>Take Care
>Arch
> Hey Folks!
> have all the pics. Heres my problem---------I used a NAPA part #
> posted here some time ago. I also checked other sources. I can not
> find front brake hoses that will work. Can I bend the steel line that
> comes off the banjo fitting????? Never bent that kind of steel line
> before.
> mechanical part of this rehab and now I up against the wall. I was
> planning to roll this weekend-------?????????
Arch,
Ray Curtis' price list shows a Part No. SP6514($43.71) for the left and
SP5766($48.12) for the right, but he doesn't say whose part numbers they
are. Give Ray a call. He stocks them and the price is reasonable
enough.
Patrick
Patrick Flowers
Mailto:patri63
The GMC Motorhome Page
http://www.gmcmotorhome.com
> and SP5766($48.12) for the right, but he doesn't say whose part
> numbers they are.
They're Car Quest part numbers(should have read to the last page before
posting). The article does say the metal ends must be bent to clear the
ball joints and you need two new "end bolts"(maybe the banjo bolts?), GM
14000404.
Patrick
Patrick Flowers
Mailto:patri63
Arch:
Are you still in need of any part numbers????
Although my information is at home, I have a complete list of the parts
for the 80 mm calipers. Installed them in Mar 1995. Can e-mail info to
you tonight if needed.
Paul Bartz
> From: Gcbr [SMTP:Gcbr]
> Sent: Wednesday, May 13, 1998 9:36 AM
> Subject: Re: GMC: Thanks
> In a message dated 98-05-13 07:01:28 EDT, you write:
> numbers they are.
> before posting). The article does say the metal ends must be bent to
> clear the ball joints and you need two new "end bolts"(maybe the banjo
> bolts?), GM 14000404.
> Patrick
> Thanks for the help. I have the article I dont like the end on the
> hose. I also dont know far you can bend the steel line on the end of
> the hose. I have a line on the banjo bolts. Just dont like the setup
> at this time. I also dont like one other thing. I dont know how many
> people have done this mod with Alcoa wheels. The clearence between the
> Alcoa wheel is only about 3/8 of an inch. Think I will take a die
> grinder and see if I can open it up a bit. I have a gravel road to my
> place and dont like the looks of this. I will send pics soon. I have
> lots of them should I spread them over several days or can you handle
> 20 E-mails with attachments in one day?
> Arch
Arch:
Yes to the Alcoa's. No to any problems.
Paul
> -----Original Message-----
> Sent: Wednesday, May 13, 1998 12:56 PM
> To: gmcmotorhome
> Paul
> BTW are you running Alcoa wheels? If so have you had any problems with
> the close spacing between the wheel and the caliper?
