Testing for battery drain.
LarryW
6,022
746
113
Menomonie, WI.
My engine battery drains nearly dead in about 5 days. Charge it and disconnect from coach and it looses nothing, Hookied up it will go from 13.4v to
11.5v over a 5 day period. What is the best way to test for parasitic drain?
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Put a test light between the negative battery terminal and the negative
lead. If you have a drain the test light will illuminate. Start pulling
fuses one by one while watching the light. The one(s) that makes the light
dim or go out are your issue.
Sully
Bellevue wa
> 13.4v to
> drain?
> Larry
> Menomonie, WI.
> Sully
> Bellevue wa
> > 13.4v to
> > drain?
> > Larry
> > Menomonie, WI.
That is exactly what I was looking for! Thanks Sully!!
Larry
Menomonie, WI.
Used it myself for the first time on my first GMC. Thank you James Hupy.
Sully
Bellevue wa
> light
> > Sully
> > Bellevue wa
> from
> > > 13.4v to
> > > drain?
> > > Larry
> > > Menomonie, WI.
> > > GMCnet mailing list
> Larry
> Menomonie, WI.
