Technical Service Bulletins for 1973 Oldsmobile Toronado V8-455 VIN W 4-bbl. Provided by ALLDATA
dave hilsdorf
7
http://www.alldata.com/consumer/TSB/43/734305DK.html
Service Bulletins
TSB Number Issue Date TSB Title
1. ATRATB010 SEP 90 Torque Converter Identification
2. ATRATB8834 JUL 88 Identifying Correct Sprag Rotation -
Auto Transmission
3. ATRATB8816 MAR 88 No Upshift - Governor Contamination
4. ATRATB887 FEB 88 Checking Pressure Switches For Leaks
5. ATRATB861 JAN 86 Rapid Pump Bushing Wear
6. 74T4 OCT 73 Ignition Timing Indicator
I wish I could find something like this for the actual GMC itself.
DaveHilsdorf
1973 260
- --------------6BC03118E86
Content-Type: text/html; charset=us-ascii; name="734305DK.html"
Content-Transfer-Encoding: 7bit
Content-Disposition: inline; filename="734305DK.html"
Content-Base: "http://www.alldata.com/consumer/TSB/43
/734305DK.html"
Automotive Recalls and Technical Service Bulletins for 1973 Oldsmobile Toronado V8-455 VIN W 4-bbl. Provided by ALLDATA
Provided by ALLDATA
/images/[URL="http://tl.gif"]tl.gif[/img][/url]
contest.htm t=_self]Enter to win a Personal Edition CD-ROM Disc by clicking here[/url]
Service Bulletins
Code:
<b> TSB Number Issue Date TSB Title</b><OL><LI> ATRATB010 SEP 90 Torque Converter Identification
<LI> ATRATB8834 JUL 88 Identifying Correct Sprag Rotation - Auto Transmission
<LI> ATRATB8816 MAR 88 No Upshift - Governor Contamination
<LI> ATRATB887 FEB 88 Checking Pressure Switches For Leaks
<LI> ATRATB861 JAN 86 Rapid Pump Bushing Wear
<LI> 74T4 OCT 73 Ignition Timing Indicator
</UL>
[ en.html t=_self]Select a different engine[/url] |
mo.html t=_self]Select a different model[/url] |
mk.html t=_self]Select a different make[/url] |
yr.html t=_self]Select a different year[/url] |
index.html t=_self]Return to the ALLDATA Home Page[/url] ]
For information on how to get an ALLDATA Personal
Edition CDROM Disc for your vehicle, click here
See if ALLDATA has a Personal
Edition CD-ROM Disc for your vehicle.
http://vehicle.[/b]
zip.html t=_self]Locate a Shop that uses ALLDATA information to repair vehicles, click here[/url]
ALLDATA has obtained this information from the original equipment manufacturers
and others and ALLDATA believes it to be reliable. However, ALLDATA makes no
warranty regarding the information, express or implied, and accepts no
responsibility for the accurancy or completeness of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct,
indirect, incidental, special or consequential damages arising out of the
use or inability to use this information.
&copy; 1998, ALLDATA Corporation. All rights reserved.
- --------------6BC03118E86--
