Tail Light Upgrade
Mike Perez
499
142
43
I'm happy to finally show an upgrade for the tail lights. The video below shows the instructions on how to install and what comes in the kit. If you have any questions or would like to order, please see the email information at the end of the YouTube video below.
The pricing is as follows:
LED Tail lights modified to fit the GMC housing with 1157 bulb pigtail: $89.99/pair
LED Reverse 1156 Bulb with correct orientation for older non-reflector type housings: $29.99/pair
Solid State Electronic Flasher Module for LED lights: $29.99
Shipping will be via USPS in a medium flat rate box for $13.20 to the USA. All other countries will vary depending on location and shipping speed desired.
Keep in mind, these products are not stocked in large quantities. They are made to order and first come, first served.
Addendum to the video: It was just pointed out to me that some of the newer coaches have a separate flasher module for hazard lights and one for the turn signals.
Send me a direct message or an email and I'll get you hooked up. The email as at the very end of the video. I don't like to put actual email addresses on websites because of spammers.
Hey Mike, since you're no longer making these, are there any tips/instructions you could share?
Sure. Take two of the T71 lights, sand off some of the flange that is not needed (designed for rubber boot) and connect/splice to the 1157 plug. I prefer the solder shrink type connectors. Then, use super strong double sided tape or some other way to fasten it to the metal light housing. I guess you could use thin magnets. Put the lens back on and you're done.
https://www.covertlights.com/T71-RED-STT/
https://www.summitracing.com/parts/upd-ftl1157-plug
Thanks! Do you also have a recommendation for flasher(s) that work with LED lighting?
