For what it's worth: When I first got the X-Birchaven in '98 I knew
NOTHING about GMC's, but the 3.50 chain sounded like a good idea, so,
having the engine out anyway, I had the transmission gone through and the
chain installed. I later swapped that whole front clip (front frame and
drive train) into a X-Palm Beach, which my son now owns. That drive train
probably has 85,000 miles on it -- without any problems. I discount the
proposition that the chain imposes too much load on the transmission, based
on the numerous applications where much higher torque engines are used.
And it's quieter than most final drives.
The only reason I didn't install a chain in the X-BIrchaven's current drive
train during one of it's several R&R's is that it came with JimK's 3.55,
which has been VERY satisfactory also.
JMHO,
On Thu, Dec 15, 2016 at 2:16 AM, Rob Mueller
wrote:
> Larry,
> Thanks for the memory tweak, I promised to talk to Manny about the
> reliability of the power drive when I visited him on my return to
> Sydney in August. I did and he advised he had installed numerous power
> drives (I can't remember the number he noted) and he's only
> had one problem.
> Regards,
> Rob M.
> The Pedantic Mechanic
> USAussie - Downunder
> AUS '75 Avion - The Blue Streak TZE365V100428
> USA '75 Avion - Double Trouble TZE365V100426
> USA '77 Kingsley - TZE 267V100808
> -----Original Message-----
> From: Gmclist [mailto:gmclist-bounces] On Behalf Of Larry
> Sent: Thursday, December 15, 2016 12:11 PM
> To: gmclist
> Subject: Re: [GMCnet] Switch pitch transmissions. A want or a need?
> > Can you fit the Manny chain and sprocket without pulling the
> engine/transmission?
> No. Gotta pull the trans to do it. Take off the chain and sprocket back
> cover to change the parts out and put the trans back in. The
> other option is to change out the final drive from your 3.21 to one of
> Jimmy K's 3.70's. That way you wouldn't have to drop the
> trans. Problem is, that 3.21 is a strong bullet proof unit. As I said
> before, the 3.50 sprocket set with the 3.21 FD gives you an
> effective 3.70. IIRC price on the sprocket set is about the same as a
> 3.70, but IMO that 3.70 FD is a somewhat weaker unit than the
> 3.21. Some have said that the sprocket set puts more strain on the
> transmission, but I personally have not seen evidence to support
> that. Most who have a 3.70 gear ratio...be it the combo 3.21 FD with 3.50
> gear set, or the 3.70 FD have been very pleased with
> performance and no change in gas mileage...even though the engine is
> spinning more rpm's per mile. Either way, towing through the
> mountains is significantly easier with the 3.70. JMHO
> Larry
> 78 Royale w/500 Caddy
> Menomonie, WI.
