Hardie Johnson writes...
> Also could it be your torsion bars have gone soft over time?
In the bicycle world, there is a myth that bicycle frames go soft over
a period of years with heavy use. It has been fully debunked. The
stiffness properties of steel do not change over time, or with load.
What does change is the strength, with work hardening, if the stress
is anywhere close to yield strength. But that should not have any
effect on torsion bars.
And steel that is excessively loaded, damaged by external trauma, or
that was improperly tempered may get brittle and develop fatigue
cracks. A crack isn't strong or stiff at all, and I think that's is
what is behind the perception that it has gone soft. Any part that has
lost rigidity because of fatigue cracks needs to be replaced
immediately, particularly if it's the only thing holding up the coach,
heh, heh.
I've seen reports of torsion bars that have sagged over time. I don't
think they are any softer than they were, they have just yielded a
little here and there as a result of a particularly bad bump. Or they
are cracking from fatigue. If the former, they can be readjusted. If
the latter, they need to be replaced.
Rick "thinking we'd be in real trouble if steel goes soft over time"
Denney
'73 230 Ex-Glacier "Jaws"
Northern Virginia
To unsubscribe send a blank email to mailto:unsubscribe-gmclist
