Suzuki Samurai toad
Apr 8, 1998
32
Larry,
I bought a 94 Samurai in the spring to tow behind my GMC. It's a
manual trans-4wd and I asked on the Suzuki user net about towing it.
I was told by all the experts that you tow with the transfer case in
neutral and the trans in 2nd gear so the trans will oil. I towed mine
two weeks ago and I only got 30 miles before it threw the rear drive
shaft. The nut backed off the transfer case and the entire drive
shaft came off and I was unable to find it. A new one with parts just
cost me $400. We love the Zuk but look over the drive line before you
tow it. I also have some links for after market Zuk parts if you are
interested. Use this for what it's worth.
Thanks
>Did we decide that the Samurai (manual trans-4wd) can be towed four wheels
>down???? I can pick up a pretty nice one for $2.9k. Also, I am resigning
>myself that this city that I live in of 170,000 has not one mechanic who
>wants to install a new final drive. Larry Nelson, Springfield, MO, PB 75
Dave Melton
1975 GMC
26' Palm Beach
Espanola N.M.
I've pulled my '89 Tracker (identical to to the 'Zuk) for 3000+ miles, case in
neutral and auto trans in neutral. Absolutely no problems.
Gary
North Bend, Oregon Coast
> Larry,
> Thanks
> Dave Melton
> 1975 GMC
> 26' Palm Beach
> Espanola N.M.
I've got 5000+ towing my 91 got tracker, no problems, Tows like it is
not there.
J.R. Wright
GMC GreatLaker
Michigan
> Gary
> > Larry,
> > Thanks
> > Dave Melton
> > 1975 GMC
> > 26' Palm Beach
> > Espanola N.M.
I do!
Have a 1987 Suzuki Samurai. Official weight is 2097 lbs. (curb wt),
about as light as you can get.
Use a simple $99 tow bar from Camp World. Works great - on level
ground you don't even know it's there.
Got it for $1200 - then put new tires, tow package, shocks, brakes and
paint. Have about $2000 in it now. Really nice ones bring $2500-4000 and
some even more. Found over 1000 sites on the web supporting them.
You can even get a Turbo Diesel Engine for them! Not sure why???
Have some pics of mine at http://www.songtek.com/gmc/74gmc28.htm
To tow - unlock steering (key must stay in and unlocked but NOT "ON")
put xfer case and gearshift both in neutral.
Mike F.
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of
LNelson208
Sent: Tuesday, August 03, 1999 7:03 PM
To: GMCMOTORHOME
Subject: GMC: Suzuki Samurai toad
> My Tracker manual says to put trany in second , not neutral. wonser why
> gene
Gene,
Only the transfer case should be in neutral. The trans should be in
gear - I don't know why second would be specified. Leaving the trans in
gear keeps the trans internals from turning. Then, supposedly, only the
transfer case gets any wear.
Patrick
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
Larry,
I built my own brackets and use the Low cost Reese Tow bar from J.C.
Whitney. Can hardly tell it is there. I do not use any auxiliary
braking on the towed. 2500# and under I believe that it in not
necessary and I have pulled down I-77 to Myrtle Beach this spring thru
the eastern mountains and never felt under braked.
J.R.Wright
GMC GreatLaker
Michigan
> Okay, I am now the proud owner of an '88 Samurai with 103,500 miles. Runs
> great. Local Samuarai mechanic said " 103k miles......don't even sweat it!"...
> Now, I have searched for an unobtrusive set of towing "plates" but only can
> find the big nasty lokking ones in camping world catalog....any suggestions?
> Also, I have a Brake Buddy still in an unopened box but am not sure I need
> one for towing only 2,000# plus the 500# of junk I will probably have on
> board..... Larry in MO with hairpiece flyin' in the breeze, PB 75
