My GMC has been sitting cozy in it's garage since last year since I have been spending my free time Caribbean sailing instead of land yachting.
Unfortunately, the drivers side bag completely deflated as I have a slow leak somewhere. The pump wouldn't raise it. Of course that side is right
against the garage wall. Only way I could get there is crawling along the floor as I didn't fit between the wall and the beltline of the coach.
I first thought it was a bad valve or switch on the system, so I removed the line from the bag and put a schrader valve on with one hand and not being
able to see under the fender... Still no luck. 120 lbs of compressor wouldn't budge it. Slid a floor jack in and got a jack hook under the bogie and
was able to raise it 3-4 inches. At that point, the bag would take air.
My battery is also dead, charging now so I can pull it out and get a better look at what went wrong. I am hoping that there isn't bag damage from the
full deflation.
Thought I would tell the group in case anyone else has this problem. I have dash gauges on each bag. The symptom was that the pressure on that bag
would go up to 100 lbs as soon as the pump turned on but the bag would not inflate.
Will keep you all posted.
Mike
77 Palm Beach, 260, 403
Dublin, OH
http://teamteets.com/gmc/
full deflation.
Mike
Dublin, OH
