Suburban SF-30 Installation
antnip
799
In the time it took you to write this note, you could have knocked something
else off that list. Get back to work!!!
Just kidding. I have been getting tired just reading about your hard work!!
We are all rooting for you...go, go, GO!!
Tony Bad
To:
Sent: Tuesday, August 01, 2000 2:07 PM
Subject: GMC: Suburban SF-30 Installation
> I installed the Suburban SF-30 under the sink in my 73 Painted Desert.
> I installed it to the left of the original location about 4" (the SF-30
> is much lower profile than the old NT-22). The exhaust/vent on the unit
> is on the left side, the NT-22 had it on the right side. I used the old
> vent hole as a service access door. Where I mounted it I have access to
> service switch, gas hookup and control board. I just re-installed the
> old vent with a piece of rubber sheet to seal it up. I will pickup a
> service door from Campers World when I get a chance.
> Furnace is quieter and takes up less space and really puts out some
> heat. I have a 24x18x10 space under the unit to keep pots, pans and
> Budweisers where nothing was available before.
> Thanks to all who had suggestions on the install. Also replaced the
> isolator which was shot with a 120 amp unit. Combiner required rewiring
> and I dont have time. Can I use a combiner to feed the starting battery
> and put a combiner after the isolator to feed front and rear coach
> batteries seperately at a later date?
> Two more items off the list, 98 left to go by Saturday!
> Ron and Julie
Ron and Julie
Do you think I have time for a quick 6 foot chassis extension and paint job.
Unfortulately work takes up about 12 hours a day.
Ron
> Tony Bad
> From: Ronald Kazi
> To:
> > Ron and Julie
Hummmmm
Combiner requires no rewiring. Uses the same wires as the isolator.
gene
>Ron and Julie
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
That is exactly what I thought. The combiner I got from West Marine showed
(I believe) the ground being hooked up to the combiner. I consider myself
pretty good with schematics (old electronics hobby) but found the drawings
confusing. I am sure stress has something to do with it.
Given enough time to think about it, followed by consultation with our
resident gurus, I am sure I could have figured it out. For now, it was
easier to take the 20 second time out and punt.
Ron and Julie
> Hummmmm
> gene
> >Ron and Julie
> mr.erf
Yep there is a ground , and that is because there are electronic elements
in there.... Good luck, give me a note when you have the time and we will
work on it.
gene
>Ron and Julie
> > Hummmmm
> > gene
> > >Ron and Julie
> > mr.erf
mr.erf
I will do that. Thanks Gene.
Ron and Julie
> work on it.
> gene
> >Ron and Julie
> > > Hummmmm
> > > gene
> > > >Ron and Julie
> > > mr.erf
> mr.erf
