Suburban Furnace
wrightjohn 2646
4,030
John,
As for trying to make the Solaire Furnace work, parts are very hard to find, if not impossible. When I checked on Ebay I got 2 results for insect screens.
I had a number of sol-aire parts 2 years ago and I could not give them away. I had one board, several wire sets for the igniter and 3 new ignitors. They laid on my sales table marked free and no one every touched them. My HPO is that you need to consider upgrading to a suburban furnace and there are several that will fit without mods and some models with slight modification. Unless you can assure yourself that the firebox does not have a leaks and you can find parts it is a study in frustration.
Suburban furnace installations:
http://www.gmcmhphotos.com/photos/suburban-furnace-replace/p42705-new-suburban-furnace.html
Be sure and have full 12 VDC+ at the furnace, if not you can have problems of the furnace trying to start and run.
JR Wright
78 Buskirk Stretch
75 Avion
Michigan
> Stock --beige like material
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
> Source America First
I hucked my solaire furnace and found a much later model suburban 30k btu
on Craigslist for $250. The amount of work involved in accessing the
solaire (if it's buried in the kitchen cabinet like mine was) is not worth
the trouble of trial and error repair attempts. I did have to modify the
exterior for the suburban but now if there is an issue the whole thing can
be slid out the side of the coach w/o dismantling of the kitchen cabinet.
And I don't stress about gassing myself while I sleep which is priceless.
Sully
77 eleganza 2
Seattle
> John,
> screens.
> JR Wright
> 78 Buskirk Stretch
> 75 Avion
> Michigan
> > On Oct 18, 2016, at 3:38 PM, John R. Lebetski >
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
