Subject: Engine Fire Extinguishers
Nov 8, 1999
150
May I offer a suggestion? On our sail boat I drilled a hole big enough to
accept the nozzle on the fire extinguisher. Then I covered it with a piece
of sheet metal and one screw. That way I could slide the metal cover off to
one side and look for a fire and if present stick the fire extinguisher in
the hole and discharge from relative safety. Thank goodness I never needed
it..................Terry
Terry & Diane Skinner
Webfooted in Washington
Terry, a damned good idea. See, sometimes it is the simple ones that sound
good
Pat 77 Birch
How about combing what Justin Hill did with his to having the tank in the
drivers side, have a hole with the tubing and the nozzles in the compartment.
That way you could activate if from inside the coach and not need the cabling
etc. Just my .02. Sounds like something I would do.
al
> good
> Pat 77 Birch
