Subject: Brake problem, badly need suggestions
thomas r whitton
72
Appreciate your suggestions.  I'm at my wits end.
Earlier this year the brakes on our GMC faded badly on a panic stop.  I avoided a catastrophe and, in an effort to remedy the situation, I decided to install the Hydro-Boost system.  It's now installed but something isn't right.  I'm not sure at this point if the problem is the Hydro-Boost system or the normal brake system, beyond the Hydro-Boost.  (For those not familiar, Hydro-Boost simply replaces the vacuum booster with a hydraulic ram. Everything else in the braking system remains the same.  Hydro-Boost provides more pressure to the master cylinder, which should be providing much better braking.)  The coach should stop almost like a new van but, unfortunately, it doesn't.  I've cancelled three trips trying to get this problem resolved but the brakes still are not safe for a trip.
The problems I'm having:
Inadequate braking capability in normal driving situationssuch as traffic lights, slowing for traffic, etc.
Brakes are capable of good stopping in hard braking or panicsituations with maximum pedal effort but the brake light comes on.
Limited gradual braking with light to medium pedal effort (too much effort in normal stop and go traffic).
Excessive pedal effort to brake normally.
What's been done and added:
Rebuilt Hydro Boost unit originally from nineties Astro Van.
Custom mounting flange.
Custom rear clevis.
Custom mounting on brake pedal cylinder.
Power steering cooler from donor Ford vehicle.
New hoses to and from power steering pump, Hydro Boostunit, power steering unit and cooler.
Rebuilt original calipers from donor GMC motorhome.
New front brake hoses.
New front stainless-steel brake lines from master cylinderto distribution valve.
New distribution valve.
New master cylinder.
New power steering fluid reservoir.
New power steering pump.
Four new rear wheel cylinders.
Four new brake drums.
Front P30 calipers were replaced with restored original calipers with yellow sticky pads.
Good performance friction rear brake shoes were reinstalled.
System has been thoroughly pressure bled on all six wheels multipletimes.
Tom Whitton
26 foot updated GMC
Paducah, KY
Tom,
Is this a Bob Stone setup? If so I would suggest that you talk with him.
He is so close to you. He is real knowledge about the system. He
unfortunately does not use the internet. Have you checked the brake
pressure at the front and rear.
This is the one that I bought and use for testing.
https://www.ebay.com/itm/Leed-Brakes-BPG001-Brake-Pressure-Gauge-Kit-0-3000-psi-1-8-NPT-Thread-Includes/113986345531?hash=item1a8a1d9a3b:g:EV0AAOSw7qRd2rmM
J.R. Wright
GMC Great Laker
GMCGL Tech Editor
GMC Eastern States
GMCMHI
TZE Zone Restorations
78 Buskirk Custom 29.5' Stretch
On Mon, Dec 9, 2019 at 3:49 PM THOMAS R WHITTON via Gmclist <
> Custom rear clevis.
> unit and cooler.
> valve.
> yellow sticky pads.
> Tom Whitton
> 26 foot updated GMC
> Paducah, KY
Seems to me what makes the brake light come on is differential pressure
between brake circuits. If the brake light comes on only on hard braking, I
suspect air in the system somewhere. Given how hard it was for me to bleed
my system, I don’t doubt the difficulty for even experienced mechanics to
get all the air out.
I recall hearing KenH tell the story of bleeding every flare joint, on
Bobby Moore’s insistence.
Rick “who spent two days bleeding about two gallons through the system
before being (somewhat) satisfied” Denney
On Mon, Dec 9, 2019 at 5:49 PM THOMAS R WHITTON via Gmclist <
> Custom rear clevis.
> unit and cooler.
> valve.
> yellow sticky pads.
> Tom Whitton
> 26 foot updated GMC
> Paducah, KY
'73 X-Glacier 230 "Jaws"
Northern Virginia
The symptoms of the light coming on suggests air in the system somewhere. The M/C to Hydroboost rod distance needs to be correct-some even suggest a
little pre load is acceptable or even preferred. Too much will definitely over heat the PS fluid though so one must be careful here. Without having
the actual pressures at the wheels you are just guessing though. The P30 MC will require additional pedal pressure for sure but I didn't decipher
weather you have one or not. Did you get a redone bell crank with the correct geometry for the booster? If not you will have an issue because the
pedal ratio won't be correct and your pedal effort will be out of wack. Checking the PS pump pressure may be in the cards also. As stated earlier, Bob
Sone is a good guy who will be more than willing to help if he can-give him a call.
Good luck,you'll get there. Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
Have the rear brake shoes been re-arched to match the new drums?
If the shoes don’t Closely match the drum dia, the shoes will flex. This can cause the poor braking issue and brake light problem you are experiencing.
Les Burt
Montreal
'75 Eleganza 26'
> 1977 Royale 101348,
> Rio Rancho, NM
If you have good PS pressure I would look at combination valve Did you replace the valve with a Chinese PV2? They have smaller ports and several
defect modes, one of which blocks fluid pressure. I had my dealer friend, at Bob Stones suggestion, buy up the last GM 1247177 /ACD 172-1350 valves.
You can get them from Bob or from Highwaystars.net. There you will see the PV2 that everyone seems to sell and the genuine GM NOS part and the
difference in price. There is a reason.
John Lebetski
Woodstock, IL
what are the problems with the china brass pv2 valve an internet search comes up with a leaking valve no information about a performance problem I to
am not happy with my brakes with all new parts spent more time bleeding the brakes than I have ever done on any other vehicle in my life as a mechanic
I do not have a light that comes on pedal feels like it hits solid after initial application good brakes at low speed not so good at highway speed
can not lock up any wheels at any speed made a panic application when a car cut me off was able to lock up the surge brakes on the tow dolly but
nothing on the coach at about 35 mph will a new old stock help Eelko Byker 1976 Eleganza
Not sure that locked-up brakes are very effective. Best to absorb the heat
energy from the friction lining through the drums or rotors, converting
inertia into heat, instead of wearing flat spots on tires with the pavement.
I have read some engineering data on braking forces that claimed the
most effective braking was achieved by converting inertia into heat via the
rotors or drums. Engineers seldom have reasons to outright lie about their
data, unlike statisticians who make their living spinning it. But, you may
have a different set of data than I do.
I have been working on brakes since I was about 14, and I will be 80
in May. These coaches will really have you scratching your head, with
different master cylinders, distribution valves, etc. we find on them. Then
throw power boosters from hydraulic systems instead of vacuum boosters, and
all bets are off. Just change one thing at a time until you achieve results.
Salem, Oregon
On Sat, Dec 14, 2019, 2:25 PM Eelko Byker via Gmclist <
> to
> mechanic
> Byker 1976 Eleganza
Not knowing exactly how you selected the parts you have i'm just going to toss this out there from what your describing.....sounds to me like your
master cylinder bore displacemrnt is to small...the light coming on, to me suggests fluid volume issue and the lack of application pressure at the low
pedal pressure sounds like master cylinder piston diameters are too small so your not moving enough fluid for effective braking on light apply.
Ive seen it the other way as well....master to big and brakes locking up at the slightest pedal application.
Just my opinion of course.....lol.
Rich Mondor,
Brockville, ON
77 Hughes 2600
I have six disk brakes including big one-ton-kit calipers up front and a
stock master cylinder. It has enough capacity to avoid a pressure mismatch,
though it uses a lot of pedal to get to maximum stopping capability.
But any air can cause a pressure mismatch on full application. With air in
a line, the pressure will build more slowly in that circuit with pedal
travel.
Rick “thinking that brake light is the first problem to diagnose” Denney
On Sat, Dec 14, 2019 at 5:48 PM tonka6cuda6--- via Gmclist <
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
Northern Virginia
Get a pressure gage and put it at the wheels and see what it reads.
Make sure the brake surfaces are not glazed .
Glazed surface does not develop much coefficient if friction.
Our shop spend considerable time on brakes so it is not straight forward.
On Sat, Dec 14, 2019 at 4:27 PM Richard Denney via Gmclist <
> travel.
> me
> low
> > Rich Mondor,
> > Brockville, ON
> > 77 Hughes 2600
> Northern Virginia
http://www.appliedgmcrvparts.com
Thanks for all the suggestions to resolve my poor braking.  I've held off on doing anything for three reasons.  First, I had to have my heart shocked in an attempt to resolve an electrical problem, causing an irregular beat.  (That was an out-patient procedure, which only worked for about three days so I guess they will try it again.)   Second, I wanted to wait until you guys had a chance to provide your suggestions.  Third, my floor jack blew a seal when I tried to raise the coach to remove the wheels for the umpteenth time.
I'm going to use my bottle jack today to get the coach up on blocks to get started again.  In order to resolve the slight "shoe-drum" point contact issue with the rear brakes, I'm going to replace all the rear shoes.  (The four drums are brand new but the shoes I've been using for the tests were very slightly worn, emphasize "very".)  How far I get today on this, I'm not sure but I'll at least get started.  My thought is I may be getting point contact until the pressure from hard braking takes hold.  New shoes for four wheels total $46, peanuts compared to what I've spent so far.  Next, I'll use my Jim Hupy pressure bleeder for again for only God knows how many times.  I cant imagine there is any air in the system but, of course, I'm not always right.
I'm slow under the best of circumstances so all the above will probably take two or three days.  After that, unless I receive other suggestions, my plan is to put it all back together and try another road test.  By all means, if you have other suggestions, please let me know as soon as you can before everything is still apart.
Thanks to everyone,
Tom Whitton26 foot updated GMCPaducah, KY
If you use "experienced" linings, be sure that you rough up the shoes or
pads with 60 grit. "WEAR A RESPIRATOR". If the drums or rotors are slick,
rough them up as well. I use the most aggressive linings I can find, and
break them in with hard use. Currently, I have 80 mm calipers with yellow
sticky pad linings on the front, coupled with metallic riveted linings on
the rear with mis-matched wheel cylinder diameters. I had occasion last
weekend to test them extensively with a drive up Interstate 5 through
Portland, Oregon, Olympia, Fort Lewis/Mchord, Tacoma, Seattle, Everett,
Washington. 6 major cities, a lot of stop n' go with a few panic stops
thrown in. Brakes work very well. I like the combination.
Salem, Oregon
On Sun, Dec 15, 2019, 10:26 AM THOMAS R WHITTON via Gmclist <
> time.
> Thanks to everyone,
Tom, in bleeding the rear Brakes sometimes I've had to raise the bogies to get the bleeders higher than the line. Meaning with wheels off and frame
blocked up, I have jacked the boogies up after dumping air on bags. Seems to help on some coaches with air bubbles in line even using a pressure or
vacuum bleeder.
> Thanks to everyone,
C. Boyd
76 Crestmont
East Tennessee
Jim, why are you using 80mm calipers?  I removed my 80mm calipers and went back to the originals as part of this current brake work.  I used the still good (maybe 75% plus) yellow sticky pads, which I understand work with both the originals and the 80mm.
Do you think going back to the 80mm calipers with new pads would have any benefit or not?  If so, this would be a good time to do it.
At least 70% of the stopping effort is by the front brakes. The bigger
caliper pistons provide more of that. Barring changing to larger diameter
rotors, it is a good upgrade without any downside. Even when I convert
coaches to all discs, or reaction arm systems, I am very much inclined to
use the original master cylinder and modify the distribution valve to
remove the delay feature to the rear brakes. I am NOT A FAN of the P-30
master cylinder or that brass distribution valve. Lots of debate here.
Salem, Oregon
On Mon, Dec 16, 2019, 10:27 AM THOMAS R WHITTON via Gmclist <
