Also check the fuel line install by opening and closing the slide.
> Always use 1/4 " new fuel line.
> The fuel pick up is designed to ever empty the fuel tank. This way you
> will have few gallon of fuel to drive on. Yes the other tank might be half
> full or empty.
> On Fri, Jul 12, 2019 at 8:42 PM Tom Newell via Gmclist <
>> Those pumps are great. They don't like lifting fuel up, though. Run it
>> with your finger over the outlet to prime it, and I bet it will work after
>> doing that.
>> I just used and old one to pump old gasoline out of my truck's tank and
>> needed to prime it as described to get it started. It then happily pumped
>> out
>> 7.5 gallons without missing a beat.
>> Good luck.
>> Tom Newell
>> San Pedro, California
>> Proud Citizen of
>> Los Angeles, California
>> Founded 1781 as
>> El Pueblo de la Reyna de los Angeles, Alta California
>> _______________________________________________
>> GMCnet mailing list
>> Unsubscribe or Change List Options:
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk
http://www.appliedgmc.com
> 1-800-752-7502
