Wayne,
I too have mounted several Alcoa sets with OEM studs and have had no
trouble. The stud just grabs all of the threads and I think is OK. I
would say though that if you are doing wheel bearings or brakes that it
wouldn't hurt to throw a set of Dorman brand 610-218 studs in. They are a
bit longer and stick out about the same as the steel rim set up did.
I ran into a set of Progressive rims lately that only grabbed @ 1/2 of the
threads, I strongly recomended swapping those out.
Jim Bounds
>Gang
>When I changed over to Alcoa's. my coach had about 37,000 miles and most of
>it's life, it had been in storage. The tires were dry-rotted, so I knew
>that I needed to get new tires and knew that I could save a lot of money by
>staying with bias tires, but a previous motorhome had them and one of my
>straight trucks was so equiped. I knew what it was like to round out the
>tires, and the jaring ride for the first few miles, so the change over. I
>did not change my studs. I did talk to as many people, and read what I
>could get my hands on. True, the studs do not come all of the way through,
>but they only lack a very small amount. I haven't had any troublle in 2
>years. All of my old studs appear to be the same length.
>Wayne Newland F9300 75 Palm Beach Columbia, Md
>> echo that... I did not change mine either. Osburn said it wasn't
>> necessary, nor did Don Wirth who I respect. Now I head for cover also.
>> al
>> > Dratted snipers! Stick your head up, take a shot and then duck!
>> > > Alan
>> > > Don't bother changing the studs for the aluminum wheels unless
>> > > they have been stretched or damaged. It just isn't necessary !
>> > > Now excuse me while I head for cover....incoming (opinions) !!
>> > > See ya
>> > > Mikeb
Jim Bounds/Co-op Motor Works Orlando
www.gmccoop.com
