stuck distributor
Ya' know, I bought a can of PB Blaster because I'd heard it was so great.
After going through one can, I went back to aerosol Liquid Wrench. LW just
worked better for me on the GMC, and I've probably used a half dozen cans so
far. IIRC, I picked up the PB Blaster at AutoZone.
Patrick
> >EMERYSTORA
> >Subject: Re: GMC: Distributor removal
Steven, It wasn't stuck too badly. WD-40 and hand operated grunt power
loosened it. Thanks for the reply.
Bob McLaughlin
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of Steven D.
Ferguson
Sent: Monday, April 03, 2000 10:00 PM
To: gmcmotorhome
Subject: GMC: Stuck distributer
Must be rust and crud where
it enters the block because the gear at the bottom shouldn't be holding
it.
I've found quite a few like that. Usually is varnish build up where the
distributer goes through the block. (In 2 places.) You can use a pipe
wrench on the raised part of the base, It's gonna leave a lasting
impression in the housing though. Sometimes it's the only way. WD
ain't gonna get it!
Steve
